Interesting development. While disassembling the front end of the engine bits, I decided it was time to drain the radiator. Petcock open, no problem, now just to go vent the top to do a good drain. Push the cap in, give it a twist...remove cap, something doesn't look right. There's a brass arc-shaped piece about an inch long sitting in the top of the radiator cap gasket area. Look at the radiator and a piece of the friggin secondary gasket (top gasket) land had broken off the neck! Surprisingly, from what I can see, the innards don't look horrible. But I can't trust just looks. Gotta be tested.
Sad. Anyway, the radiator seems to be in good shape otherwise, as it's had a screen installed in the front of the condenser all its life. No bugs or dents or anything else seemingly bad. Externally it appears to be in great shape.
I believe necks can be sourced for this, and if so, would this below work? Looks like the same thing, but I guess I'm gonna have to do some measuring to make sure. The hose nipple is spot on. Hopefully the hole sizes are the same. Has anyone had to "re-neck" their radiator? Honestly, I've never seen a neck broken before. Had one spring a leak one time, but not busted stuff.
To note, I have some soldering skills. It is NOT a hugely tough job to do. However, I'd like to take the radiator to a radiator shop and have them clean it and test it, and while it's there, just have them put the neck on it if the radiator is worth saving. Pros are better than me.
Again, like most things, I got an NOS fall back if things can't be fixed...
GM Brass Weld On Radiator Filler Neck GM -Solder On 3/8" overflow made in USA | eBay
43mm ID 57mm OD Brass Weld/Solder On Radiator Filler Neck. Filler Neck Top Opening ID: 43 mm 1.70". Filler Neck Opening OD: 57mm 2.25". 1 x Filler Neck. Material: Brass.
www.ebay.com
