Yet ANOTHER 8.8 ford rear swap question thread
soloone87
soloone87
176
hollywood,fl
So after looking around for a few days I've come up with more information than i can process, i know a fox body rear end will work and all you gotta do is weld the spring perches on and get the adjustable uppers.
BUT!
i found out that the ford explorer comes with an 8.8 5 lug with disc brakes. I have access to one of these axles and I'm really interested in using it since its a 5 lug disc brake set up and its the quickest cheapest option WITH posi already tossed in
so i guess my question is fox body vs explorer rear end what are the differences in swap procedure. i see they have an 8.8 swap kit out there now that corrects center line but will that make the ford explorer a straight bolt in swap (minus the spring perch mount)? im really confused and i need to know before i just get a posi 7.5 unit and drive it until it blows the rear axle out
Y
Yav8
237
The mustang is a 4 link set up and the Exploder is a leaf spring housing with out the brackets for the uppers or lower control arms. Plus the Exploder is wider then the early 8.8 mustang housings. Just order the 5 lug axels and use the ranger drums should be easy enough.
Reactions: soloone87
soloone87
soloone87
176
hollywood,fl
i guess that answers that question. thank you yav8 i figure ill try and find a newer gt stang rear (5-lug & disc) and see if my current wheels will work without redrilling the axles
Judge Mills
Judge Mills
199
Washington State
I did the Explorer swap on my 71' Plymouth Duster. The driver's side axle shaft and housing is longer than the passenger side, meaning you'd need to cut the driver's side to the same length as the passenger's side, and either buy two passenger side axle shafts, or find another at the junk yard.
I had an axle shop cut/weld my axle, and another shop assemble the new bearings and axles in the housing.
Y
Yav8
237
Same set up for a S-10 rear end or any thing that has a leaf spring. Some you don't even need to cut, just relocate the perches and go from their. 31 spline axels cheap posi units and a dime a dozen in the yards and a good choice of ratios. Just check the door jam for the axel and posi before you buy.
Thread starter Similar threads Forum Replies Date
cardude Yet Another Old Guy!! New Users 22
Daca214 yet another AC question General Discussion 5
pontiacgp I Don't Buy Christmas Gifts But I Ain't Scrooge (yet) OFF TOPIC 8
Kemper1976 Drag Week 2019 Participant list - Any Info Posted yet??? Drag Racing 3
Eddie Cutlass CUTLASS Another tail light/turn signal post 🤓 Electrical / Ignition / Starting 12
pagrunt Another big kid-little kid project General Discussion 0
Texas79cutty Another g body G-Body LS Swap 0
corvettez06 Another missing piece.... 8.5 Rear end G-Body Build Threads 9
lilbowtie Another anniversary General Discussion 12
dfast1 One LS out another one in G-Body LS Swap 17
-83MONTESS- Another kick in the nuts General Discussion 42
lilbowtie Another low mi - hi $$ General Discussion 8
gnvair Another odd ball 4 speed Malibu for sale (not mine) Chevrolet Monte Carlo / SS / Malibu 20
HAFROD Another dash vents not working question Cooling / Heating / AC 6
TURNA Another "custom" Camino General Discussion 13
pagrunt NAPA, another home for Craftsman?!?!?! General Discussion 9
GuysMonteSS Another Season Is Over... General Discussion 4
jlcustomz Another 2010 camaro nose el camino Photos, Videos, etc. 2
Bonnewagon Another FRAM story General Discussion 50
jlcustomz another custom for sale. Photos, Videos, etc. 4
A Another newbie New Users 7
69hurstolds CUTLASS LEAD- ANOTHER ONE (post #9)!- UNICORN Olds part- 87/88 Front Nose Emblem F/S Fleabay NOS. Not for the faint of heart. $$$ Restoration 11
wskirvin CUTLASS Another interior thread Interior 5
JAMCAR223 Another great GBody parts find - This is one of my better ones General Discussion 10
TURNA Another one bites the dust...Maple Grove General Discussion 11
rafael martinez jr rear s10 calipers on a ford 9in Wheels / Tires / Brakes 4
fleming442 Ford 9" Pinion Question Transmission / Rear End / Driveline 15
Reddzedd Ford 9" recommended gear oil? Transmission / Rear End / Driveline 8
D ? To QP Ford 9 owners Transmission / Rear End / Driveline 53
D Ford 9 ? Transmission / Rear End / Driveline 32
KCP And now to something completely different. Ford 7.3 E350 Ambulance OFF TOPIC 30
blk7gxn GM wants to merge with Ford....Thoughts General Discussion 22
Similar threads
