zr2 rear with disc brake
whitedrifter
8
I found a great shape S10 ZR2 rear end and I want to know if he fit my 86 cutlass or what i have to do to make it fit
iirc, the width is correct, but it's going to be a matter of finding a welder who can effectively weld onto the cast housing. the other option, though ugly is to weld a brace around the pumpkin and to the axle tubes.
http://www.bcgbody.com/forums/showthread.php?t=13497
here's an example of how one guy made it work for him. he used a different rear end, but the same concept.
you might be better off forking out the cash for a g-body 8.5.
Where are you located? I might be interested in it.
*votes for coil spring rear*
That was a little odd the way Foxz had his done, there is a company or two that makes a set of conversion arms for the 8.8.
