How to wire up an electric choke
TeezySupreme
482
where would be the best place to put mi electric choke 12v wire on a 1980 cutlass
axisg
2,685
2,357
YYZ
Re: electric choke
You need a switched 12v + so the wiper motor is pretty common. One of the wires off the alternator should be switched as well.
TeezySupreme
482
Re: electric choke
i gotta find out which 1 is the power wire or do u knw which 1 it is
joe_padavano
1,151
13
Northern VA
Re: electric choke
This question must come up monthly. Simply using a switched power source, especially one that is hot in the ACC position, can cause the choke to open prematurely if the key is on but the engine is not running.
GM used two different methods, depending on the vehicle. Most used an oil pressure switch in the power line to the choke. This way, the choke doesn't start to heat up until the engine is running and there is oil pressure. I ran a fused wire (20 A fuse) from the BATT terminal on the alternator to the switch, and from the switch to the choke. Very simple to wire and very clean. I like to use the Standard P/N PS64 switch. The middle terminal works the OIL light, the other two are a normally open switch that closes with oil pressure. Use these to control the choke. If you have an oil pressure gauge instead of a light, simply use a brass tee fitting to connect both this switch and your oil pressure sender.
joe_padavano-albums-electric+choke+wiring-picture5041-electric-choke-wiring-oil-press-switch.jpg
The other way is to use a relay that is triggered by the field wire on the alternator (brown #1 wire on SI-family alternators, for example). The field wire is only hot when the alternator is turning. This is how GM wired the stock G-body cars with electric choke when the gauge package was installed. Of course the down side with that is that the choke will close if you break the alternator belt. A typical wiring diagram for the second method is here:
joe_padavano-albums-electric+choke+wiring-picture5042-electric-choke-wiring-relay.jpg
Edit: added schematic for oil pressure switch option
  • Informative
Reactions: 5 users
TeezySupreme
482
Re: electric choke
ok i get it i will be gettin my oil pressure switch asap
Bonnewagon
Lost in the Labyrinth
10,618
14,421
Queens, NY
Re: electric choke
That is the best explanation I've ever seen for the electric choke!
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,197
9,850
Gainesville, Fl
Re: electric choke
I agree. This definitely should be a sticky.
Very nice write-up, Joe. Well done.
dougfather
286
5
16
Altoona PA
Re: electric choke
I just now found this and need to do this for my V8/gauge swap. Sticky it is.
And of course move it to a more deserving forum. "Electrical and Interior".
cashmoneyspeed
163
6
Chicago
Re: electric choke
For my electric choke, I tapped into the 12V wire into the pink wire coming off the distributor. Good info with that oil pressure switch, might just have to do mine that way with a tee when i hook up my oil psi gauge.
