1985 with a 305 starts but then dies
Hedge
n00b
Mar 20, 2023
My El Camino was put away for the winter and I was getting it out for the spring and I went to start it and it ran for 3-5 seconds then it died. So far I've gotten new spark plugs, fuel filter, spark plug wires, and exhaust manifold gaskets. The carb is getting fuel but was wondering if it could be the something within the carb. This is the first time the cars been in winter as it was in Texas and Arizona for it's entire life and now it's in Illinois so just figured I'd ask here before I sink even more money into something that might not be the issue.
86LK
1,976
2,042
what carb? bowl floats? did you put fuel stabilizer in it for the winter? HOW did you verify carb is getting fuel?
Hedge
n00b
Mar 20, 2023
OEM carb, no fuel stabilizer, and after I put the new fuel filter in I started it it died I took it out to verify I put it in the right way and the fuel was pressurized as I was taking out the filter so I'd assume that means fuel is getting to the carb
Clone TIE Pilot
3,861
2,612
Galaxy far far away
Its either flooding or running out of fuel. Quite possible the fuel gunked up in the carb over the winter.
g0thiac
939
582
Thanks, I'll take it apart and clean it to see if that works
If you have decent known pressure, then it's either the carb, distributor or a vacuum leak.
You said, that you did exhaust manifold gaskets, was the carb or intake ever done- check those bolts as well- but if it has sat over winter, and now the problems have happened?
Then it shouldn't be much that needs to get it in good running order again 💯💯
86LK
1,976
2,042
what kind of fuel filter? one of those porous metal ones where the fuel line connects to the carb?
have you tried starting with the line discon'd and pumping into a cup to see what kind of pressure you're getting?
MrSony
6,831
6,741
Des Moines, Iowa
Ethanol laced fuel turns to a powder when it evaporates. Clogged my carb up. Looked like someone poured sugar in it.
oldsmobile joe
2,067
3,053
mpls
check your choke. remove the air cleaner lid and make sure the choke closes when the gas pedal is depressed. this sets the choke. now start the engine, or have someone start it while observing the choke blade. once started, the choke should open to let air in. you can manually adjust this the blade during warm up to see if it needs more air or not. if the choke doesn't close, you have a choke stat problem. if the blade doesn't crack open when running, you have a "choke pull off" or also called "vacuum break" problem.
good luck
daufenbm
6
New vs old fuel. Also right amount. Some areas down there are different elevation lead to rich/lean situation.
