More harness
The pin tool pushed the holding pin down and the connector slides out the back.
Don't forget to take out the Lock Comb before starting to de-pin (like I did
The Lock Comb goes in under the pins and is a secondary way of keeping the pins locked in place.
I do 1 pin at a time to make sure they all go back where they came from.
Crimp
Solder
8 times later and half the C100 Connector is done.
Do it all over again and both are done.
Adding Dielectric Grease to the backside of the new pins.
Snap the 2 halves back together
Add some wire loom and it almost looks professional.
Hutch
