BUILD THREAD 1987 Olds 442 Project Build
oldsofb
1,384
4,014
Maryland
That is beyond words cool 😎
Thanks! It was more difficult than I thought it would be. Mostly due to my bad welding.
69hurstolds
8,199
17,601
That worked out very well. Nice to see the Oldsmobile out front.
oldsofb
1,384
4,014
Maryland
oldsofb
1,384
4,014
Maryland
Back at it. Getting the intake squared away.
Once I get it off the car, I walk it out to the shed where my drill press is. I balance it on an 8x8 post and lock the front runners down with some screw in vice grips. (Don't try this at home....wait, I AM at home!)
I put it on the press to make sure the hole I cut was parallel with the cast one on the passenger side coolant runner.
With the hole drilled I moved on to smoothing out the nasty seams and casting flash on the sides of the carb pads.
That red scotchbrite would have taken forever. I switched up to a 36 grit pad, then up to 80 grit.
Satisfied with my initial smoothing out of the sides, I moved on to installing the sensor bung I got for the driver side runner. I thought I got the right drill bit to have a nice interference fit on the two, but after heating the manifold and freezing the bung it still wouldn't fit. I used a grinding stone to open the hole a little and love tapped the bung into place.
This will allow me to run the cooling fans from a passenger side coolant sensor (with the wiring kit I bought) and run the stock sensor for the Rally Gauges on the drivers side.
With the bung solidly in place, I went to a guy to get it TIG welded in place.
I used 2" and 3" red scotchbrite pads along with a curved file to smooth out the weld and blend it in to the runner.
Still need to prime, sand, prime, sand, paint, but that's all for now.
Hutch
Reactions: 15 users
mclellan83
4,270
9,483
Pgh, PA
Was it this guy you took it to?
