81X11 said:- Have not figured out the proper timing yet. Set it like the 307 and it idles really rough and starts hard. Will have to Google the proper timing for the 350.
Your base timing needs to be set to whatever will end up giving you the proper amount of total timing ( which should be around 36 ). Hard starts are usually caused by having too much base timing and/or a high CR. Higher base timing will give you a smoother idle though, so it seems odd you're getting the bad side effects of too high base timing but with out the benefits. Maybe it ain't even timing related. Are you running full manifold vacuum to the distributor or ported? Does it smooth out when you advance or retard the distributor while it's running?
- Temp gauge is dead now, worked with the 307. The hole in the Edelbrock intake is larger than the stock 307 intake. I bought an adaptor at Napa, and it's bolted in, but still getting no reading. Either the sender is bad, or the adaptor raised the sensor up too high to get a good reading....?
The adaptor shouldn't effect it. Doesn't your intake have a proper sized port right next to the one you're using with the adaptor fitting? If so, just use that port.
- I had to install a dropped-base aftermarket air cleaner to close the hood. Put my Rocket 350 decal on it. Looks ok.
What intake are you running? Unless it's an RPM, I can't see how you'd be forced to use a dropbase air cleaner. :?
- Still have to sort the huge wiring mess out. Have not removed the ECM harness under the hood yet, but really want to do that.
Cut the wires where they all join together and 'dissappear' under the AC module. Now all of those wires under the hood are gone. Now remove the passenger side kick panel and unplug the ECM and the other big connector that's for the underdash CCC wiring that route to the drivers side. Remove ECM and pull what's remaining of the CCC wiring under the hood through the rubber grommet in the firewall and you're done. 5 minute job, much longer if you want to remove the CCC wiring intact ( because you need to remove the grommet ).
Stole power from that harness to run the electric choke, and once removed will have to find a new power source.
No you don't. You can still tap into the ECM wiring that's still there under your dash by routing your electric choke wire through the rubber grommet and connecting it to the F pin on the big connector ( the very same connector you unplugged to remove the ECM. This is how mine is. It's clean and required no splicing.
Also it looks like the plug for the disributor is tied into this wiring (?). I have it all bunched up near the evap box near the engine, and it's such a jumbled mess it's hard to tell what goes where. I did install a vaccum-style distributor but did not mod any wires yet.
The 4 prong plug that plugs into the CCC distributor is simply part of the CCC wiring harness that will come out when you remove the rest of it. Note, on at least some years, there's a small 2 prong 'weatherpack' plug in the AC area that plugs into the CCC harness ( or is that the engine wiring harness???? ). If it's connected to the CCC harness, just unplug it.
- Plugged off the PCV port on the carb and installed chrome vent caps on the chrome valve covers. They have the caps with the port for a hose and inline PCV, but don't think I need it. Thoughts?
PCV is important and don't see a need to change anything related to it in any way. You can put a breather on the driver's side valve cover though instead of the factory one with the tube that goes to the air cleaner. I'm currently running the factory breather without the hose which does the same thing as a breather since it still has the openning in it.
- Still have not sorted out how the a/c is supposed to be wired to work.
Do that last. I think it only involves bypassing the AC relay.
- Still need to figure out how to hook the cruise control to the new carb.
You're going to have to add a 'nub' onto your carb linkage to attach the cruise arm. Qjet's rule baby!
That sucks about Terrence's car! If theives are caught, they should be able to be tortured at the whim of the victims
