80 wagon front door window felts
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,178
9,800
Gainesville, Fl
Glass run channel is what I need I called them the felts
NOS type run channel is not available for A/G-body wagons per se. I was able (and fortunate) to find an OEM driver side run channel from a GM dealer. This was several years back. These are not reproduced as a ready to install unit. My friend who has a Cutlass Cruiser wagon ended up purchasing run channels for a B-body GM vehicle. The upright /vertical portion is allegedly a proper fit, but the forward top portion is a tad too short. You will need to find an aftermarket strip and splice it onto the new vertical (B-pillar) channel. I'll go back and find the part # for you.
https://www.rockauto.com/en/moreinfo.php?pk=1859214&cc=1049396&jsn=899&jsn=899 There is a list of them on RockAuto for a 4-dr '80 Impala.
Check these out in the meantime.
Of course, your other option is to find a good set out of a 4-dr G-body, and that's like trying to find the elusive Hen's teeth.
Longroof79
Oct 14, 2008
12,178
9,800
Gainesville, Fl
The 4dr and wagon rear doors are different. The wagon is square, and the sedan slopes down toward the trunk.
Bruce,
That would be more of a concern for door weather stripping replacement, or replacing doors.
