83 Buick Regal Estate Wagon 5.3 LS, bagged
Houston78
May 13, 2008
94
256
53
Houston, TX
Nice work you have done to your ride! I laughed when your dog took off of the first start video, he was caught off guard...:LOL:
vandall
109
187
Seattle, WA
As the world turns... lol. The last time I updated it was all working pretty well. I still had to get the engine ECU tuned up, the airbags would deflate pretty quickly (like over a couple nights if it sat) and they were blowing the fuse at an alarming rate. So I figured might as well take everything apart!! I think the lockdowns helped influence this decision plus I had a little cash to spend so I figured why not tear it apart for build 2.0!
Here is the set up when I decided to really get after it. This is right around May 2020.
just for reference here is the old harness coming off.. it was a clean job and worked, and I like OEM equipment.. but getting a little upgrade
here is the factory computer and fuses for the main circuits - fuel pump, electric fans, and air bag system
I also wanted to take some time to clean up everything like the wire runs, looms, connectors, finishes, etc
I'm trading this rat's nest for a shiny new one
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,177
9,796
Gainesville, Fl
Lookin' good, Randy.
That's nothing, I've seen far worse "rat's nests" out there. Still a pretty nice install. ;)
I'm sure you'll clean it up more to your liking.
vandall
109
187
Seattle, WA
Thanks Jack and others for the kind words! Here are some more photos of those early thrash days that seem to inevitably stretch into weeks and months. Haha
A little hint at what is to come! :) As you can see I attempted to retrofit in to the old computer slot on the passenger kick panel
Here's where that goes, which is a bit tight.. especially considering the vast amount of wiring. Those old computers had minimal connections compared to new stuff
Here's my vent controller below the steering column that the dealer clipped when installing AC. It shows my old "security" device which is just a switch controlling the fuel pump signal, which works well. It will fire for a second and then just crank and crank.. I got the idea from Adam Carolla. Lol
The old pedal had to go because the different type of connector
64nailhead
Goat Herder
Dec 1, 2014
5,717
12,241
Upstate NY
What trans are you using?
vandall
109
187
Seattle, WA
Hey 64nailhead, I am running the stock (2004?) 4L60E with a Holley crossmember. We pulled it due to the 1-2 clutches having burned up. I forget exactly what had caused it, but it may be earlier in the thread. We got some rebuild kit with a few upgraded pieces and did it in the garage.
The first pics are of the engine bay cleaned up and the wiring removed. I had a piece of heavy gauge sheetmetal holding the radiator down so I wanted to fix that up and clean the compartment a little.
For the gas pedal it's just mocked up here and I will show more how we got that to mount solid and in a good position. You can't really see it but the plane of the old pedal was just a bit in front of the brake pedal which can be annoying.. I didn't realize before how being able to quickly slide your foot over from brake to gas is really nice.
Still a few straggler wires to move.. at this point we didn't know where anything would go yet
I laid out the main harness to see how things might fit. It's nicely finished
vandall
109
187
Seattle, WA
We had to plug two large holes (iirc even a few small ones too) that the dealer cut to run the AC install. This one under the heater box had to be opened up again to run the new harnesses through since we are mounting the ECU inside the cabin. It's not the most elegant method and I did research bulkhead fittings but could not find one that would work due to how close this is to a seam in the firewall.
On the pedal we had to fab a small pedestal type mount so we used 3 bolts / studs to mount it. Very solid and it looks like it belongs there.
Cutting through welds is difficult..
Final pedal fitting
You can see the top bolt in this close up
Other side
vandall
109
187
Seattle, WA
I should clarify that when I said the pedestal mount looks like it belongs there, I meant it fit very well and feels solid. It really looks like hell but it's mounted where it won't be seen.. LOL. Does not look OEM
To back up a bit - we had to drop the inner fender to access the firewall. I love the plastic fenders as they can bend a bit and have places to mount components.
vandall
109
187
Seattle, WA
I had to purchase the intake sensor along with a bung. I have a friend who is a metal fabricator by trade so I took it to the shop where he works in Ballard and had him aluminum weld the bung in place. It took him a few minutes.. and welding aluminum is intense!
As mentioned (probably many times before) one of my biggest gripes was the air system would somehow bleed out too quickly (most systems will lose some air over days and weeks I think), but this was driving me nuts. I sprayed everything with soap multiple times and found a very slow leak early on, replaced the fittings, replaced the lines, and finally took the manifold apart to clean the solenoids. Since I got this system used I had no idea the history and use of it, so this was my Hail Mary like Lamar Jackson throwing 60 yard end zone bombs.. ended about the same lol.
I don't know why I love a good throttle body
Laid dimes like a long payphone conversation :D
At least they are easy to service
vandall
109
187
Seattle, WA
Fast forwarding a bit... and we have contact! After much deliberation we decided sadly that the only place the computer will fit with the various garden hose gauge harnesses feeding in is sandwiched between the heater ducts and the dash, where the glove box used to be. In fact it is so tightly jammed in there we didn't really need to mount it with bolts or screws. I may have even put a zip tie on for safety haha..
It took a bit to go through the initial start up and then realize the vacuum line needs connecting bc I thought it was optional.. reading the Holley support forums is critical. Their paper directions are excellent but a couple items were somewhat unclear even after rereading them several times. Probably just user error but we worked through it and it runs great.
It's a lot to take in but it's insanely cool to be able to check all the parameters and potentially tune the computer on a laptop
Git r dun!
You can kinda see the various harnesses feeding through
Reactions: 5 users
