I run a master disconnect switch under the hood. For some reason it crapped out and in the process of confirming this I hit the hot lug with a jumper to the chassis for a split second. I didnt even see arcing but heard a light “snap” noise, instantly knew what I did. Bypassed disconnect for the time being and all is well. I was assuming i would have at least found one blown fuse but everything seems fine so far. Just wanted to pick y’alls brains on why that is, and if any damage was done, why or why not.
