Now that my car is all back together this year, a friend of mine invited me along to an autocross event. As long as I can get a helmet, I'll be driving my car.
I have a couple of questions concerning setup. Here are my specs:
~140hp, solid 1.25" front / 1" rear sway bars, "roto-joint" rear CAs, 3.73 limited slip, 2 inch rear drop springs (progressive rate, rate unknown) sitting on 1.5" spacers, adjustable rear shocks, stock front springs/shocks/CAs. The tires are Cooper Cobras (street tires). 235 front, 255 rear.
I have shocks+springs for the front but won't have time to get them in. Here's where the setup questions come in:
-How should I setup my rear suspension?
----Should I crank up the shocks to a hard setting to help stop body roll?
----Should I leave the shocks at a softer setting so it's more "balanced" with the front? (I heard that making the rear much stiffer than the front will cause understeer in RWD applications (assuming the tires keep traction...))
----Should I take out the 1.5" spacers to try to get a better center of gravity?
-Here's the "Bad Idea?" part: The front shocks/springs I have are an adjustable coilover setup. When those go in I want to change spindles and ball joints at least. I can't get that done by Sunday since I'm still shopping around for the parts yet.
----For the time being, would it be okay to use the adjustable shocks from the coilover setup as regular replacement shocks along with the stock springs? Or will this result in far too much stress on the upper shock mount?
Lastly: Helmets. I need a good helmet in order to race. I found one by "Zamp" on Summit's website for 175 bucks. It's Snell SA2010 approved. http://www.summitracing.com/parts/zsc-h ... /overview/
Is there a better helmet I could be getting for roughly the same money and if so where can I find it?
Thanks in advance!
Thanks in advance!
