I need some new battery cables. Store cables are cheap and thin. I usually buy bulk lengths of marine grade tinned copper to make cables for outboard motors. I figured I would do the same for the Bonnewagon. The issue is that I read on electrical sites that crimping is the best way to attach the lugs. Normally I solder them. Every outboard cable I have seen was soldered. Some were even crimped AND soldered. I may do that. But why would crimping be better than soldering? That doesn't make sense. Solder would encapsulate every strand of wire. The soldered surface area of contact has to be better than crimping. I have a TEMco hammer crimper that I can use in a big vise or my 12 ton press so crimping is do-able. I am leaning to crimp-then solder.
