Battery charging problem
2
Hello im sergio, new to this forum, i figured this would be the best place to ask about my cutlass’s problem. I have a 1988 Oldsmobile Cutlass Supreme Brougham, the problem is a couple months ago the battery on the car died so i replaced the battery since also it was a really old battery , after a couple days the battery drained down to almost no voltage, so i recharged it brought it back and car was good for a couple days, but battery kept dying so i figured it was an alternator problem so i replaced it with a new one. Still had the same problem, i started to check grounds and connections all seem good and tight but i still cleaned them off, but car kept draining the battery. I noticed that when the car was in idle the voltage would be at normal (13v) but as soon as i placed it in drive or reverse it would drop to about 8v to almost nothing, with lights on it would drop all the way.
One day i took off the main power terminal while car was on, an voltage went right back up as if was fixed i would place terminal back on battery n it would drop again and engine would bog down . I was wondering if any of you guys might have been in a similar problem . If so i would greatly appreciate your help.
Gonzo1970
898
1,302
"I noticed that when the car was in idle the voltage would be at normal (13v) but as soon as i placed it in drive or reverse it would drop to about 8v to almost nothing, with lights on it would drop all the way. "
Sounds to me like you got a bad alternator. Replace it.
-Gonz
Oct 14, 2008
8,832
7,793
Melville,Saskatchewan
For one thing, 13 Volts is barely charging. If a battery is low it should be closer to 14.5 volts. Is the light in the dash lighting up when it is under charging?
Gonzo1970
898
1,302
clean all your grounds...
That was my first thought, but he specifically mentioned he did it already.
Unless you meant "ALL The Grounds" as in he may not have done all of them...
-Gonz
pontiacgp
blank
Mar 31, 2006
29,270
20,418
Kitchener, Ontario
-Gonz
I saw that but I don;t know if he took the ground off and cleaned the contact point....
"i started to check grounds and connections all seem good and tight but i still cleaned them off"
Gonzo1970
898
1,302
I think the engine to firewall ground was my problem, honestly.. But, I did them all at the same time, so...
Either way, all grounds and their contact points, cleaned with sandpaper and tight.. not just one. Battery to frame AND both ends of the engine to frame ground.
-Gonz
fleming442
Captain Tenneal
Dec 26, 2013
13,046
24,221
-Gonz
....and DIABOLICAL GREASE!
