Converting to efi
rogus
312
85
Does anyone know of a good video on converting from carb to an EFI?
Built6spdMCSS
5,839
9,766
Florida Beach
There are sooooooooooooo many aftermarket options out there now so it comes down to budget and what you know. It's that simple. Do a google search, Holley Terminator X is one of the really good ones.
rogus
312
85
Thanks this is an area I know nothing about...
Built6spdMCSS
5,839
9,766
Florida Beach
What do you want to know?
Fuel system needs to be setup for EFI so that's getting the proper Tank, Fuel Pump, Regulator, little bit of wiring, lines ran right, then the system you want installed correctly.
rogus
312
85
this is something I know absolutely nothing about. Something with some step by step explanations would be useful. I don't even know which companies make the parts, ect... On this subject I am as clueless as they come...
Ernest
760
1,038
Texas
I plan to do the same as soon as i've had enough of carburetor/wideband afr tuning.
Just to hammer in a couple of ideas, my plan.... edelbrock pro-flo 4 and use an '87 monte carlo efi fuel tank complete with fuel assembly unit, then choose a good aftermarket in tank electric fuel pump.
xylorex
305
395
New Orleans, LA
Find a system you might be interested to purchase and download the installation instructions. They are very useful.
I have Edelbrock pro-flo and f.a.s.t. setups, happy with both.
stew86MCSS396
178
242
(808)
I've always wanted to EFI the r.i.p. Monte SS circa Y2K. I've acquired a lot of parts to do the conversion but it never materialized when the vehicle started showing some of it's "beyond my capability" rust holes. Before the abandonment, bought a L29 intake that I was going to plop onto the engine. Harness from a 3.1l camaro that was rewired to accommodate the L29 intake. Repinned for the 90-92 camaro ECM. Acquired a g-body efi fuel tank. Bought stainless efi feed line from one of the tubing manufacture up in Michigan. I really didn't know how to bridge the gap between the feed/return lines to the L29 intake. Also acquired a laptop, chip burner and fashioned a home brewed uv light chip eraser. Spent countless hours on the diy gmefi mailing list trying to learn how to tune all of this mess and it was like learning a foreign language.
Anyhoo...John Bzdel probably has one of the best detailed webpage of what he did to swap a LS1 into his Monte...
Built6spdMCSS
5,839
9,766
Florida Beach
John has his, I have my build thread here..
Click that link above, you will see tons of info in mine.
64nailhead
Goat Herder
Dec 1, 2014
5,717
12,241
Upstate NY
What’s your engine/trans combination, budget, intended use and HP?
Once these are answered the choices become very easy. The second one (budget) will define systems that will fit your need.
