Dye Questions
nycutlass
592
154
NY
Thank you to all that helped ! here are some updates on the briar brown journey, i am very surprised in the outcome.
Reactions: 5 users
CrammerGram69
443
145
SW, Michigan
Here's the PPG formula codes for your 67 Dark Brair Brown ('83-'84). For semi-gloss it's 25172, low-gloss it's 25229. Since it seems that PPG owns SEM there shouldn't be an issue cross the codes. If needed in PPG it'll be in the One Choice line. Don't forget to get a copy of the product sheet (P-sheet) which will explain how to apply on each different surface along with the required products.
Thank you! I needed this for my 84 regal. I too need ideas for my seats to redye... Light blue is gonna be a B!tch & I fo sho ain't gonna send my covers to SMS then get them back 4 yrs later. smh
CrammerGram69
443
145
SW, Michigan
If it helps. Gbody parts reproduces the brand new seat covers in this color. Mine in the rear are shot. but its also vinyl button tuc.
nycutlass
592
154
NY
yes i know they have new covers but i don't want to spend that kind of money on this car
CrammerGram69
443
145
SW, Michigan
I hear you, in my case i more than likely will need to. I have been searching since November with no luck finding another car with the seats mine has.
08Malibu
1,461
3,442
North Jersey
any auto paint store can match the color you will need a paint gun .its good for hard plastic parts ..when you say seat bottom i hope you are not talking about the part you sit on it;s to flexable
Not all paint companies can mix up vinyl paint. I work for a company that sells BASF products, and unfortunately, we don’t mix vinyl dye Axalta is a company that does. So if you can find a store that sells that, they might be better help.
pagrunt
9,207
15,484
Elderton, Pa
It would be a good idea to get a list of who does have mixing systems for interior parts & to what degree of materials that can be recolored. This would be SEM, PPG's One Choice & Axalta (formerly DuPont) so far as sources & should be able to supply formula numbers crossed with OE codes.
nycutlass
592
154
NY
i agree a list should be made
08Malibu
1,461
3,442
North Jersey
I’ve had good luck with DuPont over the years. Stuff lasts. I used it on some stuff on my boat and it held up great out in the sun.
melloelky
4,176
9,606
mass
keeps the riff raff outta the store..;)
