Ive been thinking about this for a little while, and id like to get a second opinion about it. The 350 thats going in the GP is the first engine ive ever "built", so im using a rebuild guide and the advice of a friend of mine that has experiece building motors. id like to follow the book to the letter, to make sure everything is done the right way, but the problem is this. when installing the pistons: i went to each cylinder and ground the rings to match, put them in the pistons, lubed everything up real well, and didnt force any of the pistons in the cylinders. the manual says that when all 8 pistons are in the block that it shouldnt be difficult to turn the crank. when i go to turn it, i have to give it some force initially to get it to rotate. my friend says that its fine and his blocks have felt the same way, but id like to be sure about it. So how much force should it take to turn the crank?Thanks
