F41 sway bars within 100 miles of Philadelphia
Trader history (0)
doood
Amateur Mechanic
Sep 24, 2020
581
794
Looking for heavy duty OEM front/rear sway bars from performance-oriented g-body (monte ss, etc.). Don't have to be pretty.
Also looking for a GP front brace if you have.
78Delta88
1,307
1,095
SW Arizona
These are 32 mm. The base with 305 is 27mm. The 32mm is 350/Auto and believe the police issue sway bar. Haven't found it yet, but they were made. Might be a unicorn now.
78Delta88
1,307
1,095
SW Arizona
Some more info...
Looks like pd fleet version was F41 beefed up a bit.
You might want to check with Cal-Sag (Chicago) if still there. Large.... Mega Large salvage yard off of 83 in Chicago. They used to have a police car section. I haven't been there in a while, but they basically had everything.
doood
Amateur Mechanic
Sep 24, 2020
581
794
Some more info...
You might want to check with Cal-Sag (Chicago) if still there. Large.... Mega Large salvage yard off of st 83 in Chicago. They used to have a police car section. I haven't been there in a while, but they basically had everything.
Oh, I figured the sway bars would be pretty common - at least one Calais I looked at in 2022 had rear sway bar, which I figured meant F41... Figured montecarlo SS wrecks are a dime a dozen.
Worst case I buy a pretty set from UMI, but figured the OEM stuff could be had at a discount by comparison.
spidereyes455
785
1,640
Northeastern PA
Pretty sure I still have several sets of F41 sway bars kicking around in the basement. Schuylkill county Pa.
Reactions: 6 users
melloelky
4,162
9,569
mass
something to keep in mind w/your search,some of those 3rd gen f-body front sway bars are a swap to these cars too and they're stout and hollow..
Reactions: 6 users
78Delta88
1,307
1,095
SW Arizona
If the firebird will then maybe a Trans Am WS6 unit would work.
spidereyes455
785
1,640
Northeastern PA
Yes, the f body front bars will fit. I've done it myself. The biggest I've ever come across on a Camaro is a 34mm. Still bigger than the 1.25 bar the g cars used, the real gem if you find one is in fact the ws6 GTA bar they are 36mm and as far as i remember they were the only f body to get the 36.
Reactions: 4 users
