Looking for 22" need bolt pattern
Young0utlaw81Cutlass
158
21
Dallas Tx.
Hey wuzup EveryGbody i had a quick question im trying to get some 22" on my 81 Cutlass Calais and i want to know the bolt pattern and offset can i use or whats the differnce dont know bout the specs are all 81-88 Oldsmobile Cutlass are th same???
Let me know Thanks
FE3X CLONE
2,714
51
48
Ohio
5x4.75 and 5x120.65 are the same thing. 120.65 is just the metric equivalent.
4.75 x 25.4 = 120.65
FE3X CLONE
2,714
51
48
Ohio
5 x 4.75 is the SAE measurement that you will find. You likely will not see anything listed as 5 x 120.65mm unless it's some weird obscure stuff.
158
21
Dallas Tx.
Alright i got Thanks and offset whats the highest i could go?
158
21
Dallas Tx.
Hey has anyGbody put 22x11 rims?? im looking at some that i like this are the specs on the bottom
Let me know if i have to do some adjustments on the back only cause im putting 22x9 in front or i just go with
22x9 all around im trying to go staggered??
http://quotes.sdwheelcorp.com/quote.php?quote=38366
Offset : 18 mm
Bolt Pattern - Standard : 5X4.75 in.
Bolt Pattern - Metric : 5x120.7 mm
Number of Bolts : 5
Center Bore : 72.6 mm
Width:
11.0 in.
Diameter:
22.0 in.
Load Rating:
1600.0 lbs.
TPMS Sensor Compatible
Yes
FE3X CLONE
2,714
51
48
Ohio
You'd have to notch the frame for an 11" rim.
