LS Powered Monte Build
JRG53
173
16
Petal, MS
Re: New Project 81 Monte Build
What intrigues me the most about a frame off is that you will know every single bolt, nut, wire, everything as opposed to just swapping a motor, paint, and wheels. Very nice work.
Also, any chance of you putting an SS nose on this build? I'm just saying!
OldBlue82
248
2
Huron County, ON Canada
The thought has crossed by mind but it all depends if i can find the entire SS nose and fender extensions for a reasonable price. I love the look of the regular nose on my 82 monte so I still cant decide :lol:
OldBlue82
248
2
Got bored today and started scraping at the thick under coat on the frame. I was shocked to find so much clean unrusted metal there was under all the oily mess. Not only that, but it seems like 70% of the frame is like that and the rest is just mostly surface rust. The only spot, no suprise is the rear rails just behind the rear wheels but they arnt even that bad. should be easy to weld new ones from conrad on with the frame off. I still plan on sand blasting but theres too much snow outside to do it yet but does this ever make me want to get my daily driver undercoated yearly! :D
OldBlue82
248
2
Picked up this 83 Grand Prix LJ For a parts car today ($150). Bought it because it came with a set of new rear rails to repair the frame however the kid who had it didnt have the patience and the car was to far gone. The front fame, floors, doors and trunk floor are rotten. Car came optioned with power windows, locks, A/C, and buckets/console (grey interior). should give me all the parts I need 8)
3 G-Bodys all in 1 room of the shop 81 monte, 83 grand prix Lj, and my cousins 78 Grand LeMans tucked in the corner :D
OldBlue82
248
2
Cut the rear frame rails out of the Grand Prix today to replace my rotted ones on the monte. They grand prix had after market rails on it, most likely the ones Conrad makes. These rails are made out of a lot heavier steel than the stock ones :D
OldBlue82
248
2
While im still waiting on snow to melt away from the barn/workshop doors so I can replace my rear frame rails, I figured I would try and box my stock lower contol arms. They turned out not bad for a first attempt and the best part is I saved money instead of buying aftermarket boxed ones :mrgreen:
OldBlue82
248
2
Blake442 said:
Did you weld the spacer for the sway bar bolts inside the control arm before you closed it up?
Yeah just remebered that before I put the first tacks in place. I ended up making my own out of some small pipe I had. At first I wasnt gonna bother because i figured it wouldnt collapse being boxed but I figued prolly a good idea.
OldBlue82
248
2
I know you were looking out for me Blake but just had to post this lol
