New LED turn signals not flashing while headlights are on
jcelk
Dec 10, 2014
91
54
I think you may need a new flasher just for led bulbs because they draw less amps
CopperNick
3,357
3,018
Canada
What I found with the 1157 bulb bases was that the contacts were shorter and shaped in an oval form rather than the incandescent versions which had a high sitting circular contact. The ovular shape could make it possible for both contacts to feed power to the led even though only one side is supposed to be powered. I had to try different mfgrs to find a design that used the old contact style with the LED head.
I also initially used the LED design that looked like multiple layers of flat plates and did not like the output they offered so I changed over to the multiple micro-light style of head and they do seem to work better.
This whole project was simply for the purpose of obtaining brighter turn signals so that the half asleep idiots that I have to deal with while heading into work in the morning actually will notice that I am trying to turn and slow down instead of trying to run me over while driving in some kind of semi-comatose back brain fugue. Sometimes I think I could set off a micro-nuke and that still wouldn't be enough light to get them to pay attention.
64nailhead
Goat Herder
Dec 1, 2014
5,711
12,220
Upstate NY
LED’s require an LED flasher.
Ernest
746
1,012
Texas
I still run regular bulbs in my malibu(79) all around and know nothing about LED switch over... perhaps this will help explain things.
CopperNick
3,357
3,018
Canada
Nice video but the commentator is only dealing with one brand and style of LED. When I did my research on available designs of the LEDS I did look at this model/type and discarded it as an option. Also be careful of Amazon, they do carry inventory on LED's but they will drive you nuts when you try to get specs for them.
The variant of bulb that he displays at the 6.50 minute mark of the video is the style that I personally elected to run and I have had none of the problems with them that he suggests will happen, beyond the headlight glitch and that is not even a major problem; just something to consider on a cold night when nothing else is more interesting.. I even managed to acquire them in an amber format just to keep the cops happy.a
