Overdrive Question - 4th gear
Cuse99
251
126
I have a 200 4R trans in my 84 El Camino and I'm looking to change the rear. Based on the following specs, I found a calculator that says I'll be at 2500 rpm at about 75pmh. For Highway I think that's reasonable.
Specs. - 4th gear: .67:1, 25.5 outside tire diameter, 3.73 rear. My 84 El Camino does not have a computer (its gone now) so I believe I the trans switches on pressure.
So here is my question. When does my car hit the 4th gear? Will it hit 4th at 65mph or will I only be in 4th at 75mph? Maybe at 60? How can I calculate this?
Thanks in advance.
86LK
1,991
2,053
post #2 "The governor controls the rpm the trans shifts at when in auto. You can have the wights shaved to adjust what rpm you want to shift at wot."
Ernest
759
1,038
Texas
I run a 700R4, similar to your 2004R and 4th(.70/OD) for me hits exactly @ 45mph, thats just easy on the throttle access road driving, and with 3.73 gearing, i run 2400rpm @ 70mph with 27" tall tires.
rfpowerdude
674
1,076
Palm Bay, Fla
Shifting to 4th is controlled by the guv'nah. It will be at a relatively low speed like 40-45mph at light throttle. So, it will shift to 4th normally. However, do you have the lockup functional with something to control it? Even if it's just a manual switch?
85Vette
n00b
Sep 23, 2023
spidereyes455
789
1,646
Northeastern PA
  • Informative
8,828
7,784
Melville,Saskatchewan
That is a great chart, quite a variance. A shift kit a little bit or governor mods can change it a lot.
