I shot my manifld with low-gloss, ultra-durable clear today after a final media blasting with red garnet followed by a thorough cleaning with Simple Green.
I got the powder from Powder-by-the-Pound (.com) and also the silicon plugs in different sizes that you use to plug holes.
Powdercoating is a b*tch to get off so you really need to mask or plug anything you don't want coated. For small threaded holes, you can just stick a bolt in each to protect the holes. I trimmed some of the plugs where I had an odd-sized opening to plug up.
Powdercoating is interesting because the metal piece you are working with is grounded and the powder get electrically charged by the gun on the way out, so you can actually see the powder get attracted to the part.
Clear powder is white when it is applied, so you can see if you missed any spots.
All masked and plugged:
Here I am shooting the bottom (actually the front since it is hanging):
After you finish coating, you carry the part (carefully) to the big oven which has been warmed up to 380 degrees. Then the part gets baked at 380 for 15 minutes.
Here it is hot from the oven:
And a closeup of the coating after it cools partway:
I will post a picture tomorrow of it unmasked and unplugged, and sitting on top of the motor. It looks pretty cool.
Jim
Jim
