Recommendation: Electric Fans
rubio9800
242
110
California
Hello everyone,
Looking to convert to an electric set up!
Any recommendations in regard to a fan set up? I plan to keep my stock radiator.
Thank you for your time
melloelky
4,162
9,569
mass
are you looking for an aftermarket one that will be a little easier to install or are you a little crafty and don't mind making something work for you? I only ask because the dodge intrepid fans and the Lincoln mark Vlll are nice pieces of o.e hardware found in junkyards and places like rockauto for reasonable money.
Reactions: 4 users
Wageslave
1,750
3,341
4th gen Firebird/Camaro radiator fans will drop in if you have the metal top plate from a (I think) Cutlass.
Reactions: 9 users
rubio9800
242
110
California
aftermarket easier install would be preferred, im still pretty new to all this and learning as i go
oldsofb
1,385
4,016
Maryland
For a V-8 305ci and higher you will probably want 2800cfm and up based on HP.
Hutch
565bbchevy
9,615
12,684
Michigan
I have Intrepid fans on both my Monte and Regal.
Reactions: 5 users
Clone TIE Pilot
3,862
2,612
Galaxy far far away
You will likely need a higher amp alternator upgrade to power the electric fans.
Reactions: 5 users
melloelky
4,162
9,569
mass
there's a lot of options available in the aftermarket and if i can recommended anything i'd go with a dual fan set up over a larger single.everyone's budget is different i would hop on Jeg's or summit racing and poke around see what catches your eye do a little window shopping..
