speedway motors boxed rear control arms
L05edSS
235
130
has anyone ever tried to put the 68-72 a-body supports in the lower bars? These are the bars I used in my 70. I have boxed many G-body arms, but you can buy that lower piece in the A-body arm and weld it in. Just wondered if that insert would fit a g-body arm.
prolly not cuz had a friend many yrs ago that took a 12 bolt out of a 70 chevelle and had to get special arms to fit in a 85 ss but heres this and speedway may have the answer for fitting polys.
bracketchev1221
1,434
1,687
No don’t pay attention to the bars. Look at the bottom picture of the a-body arms I listed. That reinforcement plate can be bought separate. Can that plate fit a g-body bar to box it
scoti
1,988
3,430
Texas
If they're available separate, the plates for the Jeg's arms should work on the g-body spec arms as well. Worst case they might require some trimming if needed. I've boxed them (A & G-body) for people using some flat .125" steel strap from the hardware store
Reactions: 4 users
doood
Amateur Mechanic
Sep 24, 2020
591
810
Looks stiff!
scoti
1,988
3,430
Texas
Looks stiff!
Definitely more than OE. I tried to sell him a new but unused set of Currie-Trac arms w/Johnny-Joints but this was for his sons high-school ride ('70 El Camino SS clone).
He did opt to utilize rubber bushings per my recommendation vs Poly units.
bracketchev1221
1,434
1,687
That was how I did my 78 back in the early 90’s. Was asking about the other way after getting into the factory f-41 70 ss suspensions. The ones I had in the race car were boxed factory arms before I changed to SSM bars.
L05edSS
235
130
ok i see what you were sayin. IDK, i agree with posters below or above this reply. i tore up the internet lookin for stock replacements after having some in my cart and went BO hrs before i had 1st chance in months to order. just something to think bout. the price for the speedway boxed arms no bushings, about 150. the sugestion for ruber bushings were moogs forgot the # ut in my seaches here from older posts seen the same # pop up for factory replacements. not sure if that helps ya ut man the parts hunt is grueling when you can b uy already boxed arms. just read close in my above posts when comes to what found amazon in reviews.
i left a ? that went unanswered was basically theres no selection to pick A or G body so what am i gettin? est advice go to speedway & iron it out if you choose.
EDIT. when said tore up the net i meant it. i am punch bowl turd on YT, found this 4 yr old vid on yt and asked "how are they on the street after 4 yrs?" he replied next day, comment is there for all to see.
403Olds
539
434
South Central Ohio
I've done several vehicles just welding in plates on the bottom from the scrap pile. My Tahoe, for example doesn't have much aftermarket support, so that's about the only option to get rid of some of the flex.
