Stock Wiring Harness
Street Sweeper22
233
91
Im trying to repair the factory wire harness for a 84 Buick 3.8 and I have an extra green wire. It comes out of the main harness at the same place as the distributor wire, alternator plug and a/c compressor plug. The a/c plug looks like it has been repaired. Any ideas on its destination? Any help is appreciated.
Ribbedroof
4,925
7,064
Wellston, OK
Dark green is usually temp sender on GM products
Street Sweeper22
233
91
I went through my whole wiring harness. Plug by plug. Its not the green wire for the compressor clutch unless there are two green wires that go to it.
stew86MCSS396
178
242
(808)
I know I know comparing a 305 V8 to a 231 V6 may be an apple to oranges comparison but see if this will help you out...
Street Sweeper22
233
91
Thanks for that bro. I’m going to double check it against mine.
Ribbedroof
4,925
7,064
Wellston, OK
Could be the Idle Stop Solenoid (ISS) or idle kicker on the carb. This is a solenoid that allows the idle to increase when A/C is active. It is de-energized when the car or A/C is shut off to prevent "dieseling" (engine run-on). This system is used to compensate for the required idle speed increase to offset the drag of the compressor, without having to raise the hard stop on the throttle shaft of the carb.
This actually makes more sense to me than the temp sender, given the location where the wire exits the harness sheathing. Kinda forgot about that since on the last one I built all that was elimnated.
