Pulled my trans to fix a front pump seal, having trouble figuring out what the trans is from. It is a TH350.
Number stamped on driver side, just above the pan: 36M292819
Top of bell housing, between top two mounting bolt holes, large raised numbers in casting C 11
Drivers side, side of bell housing raised numbers in casting: 8640239 with CFD under those numbers
Drivers side, side of bell housing, small raised circle with 2-76 and a number 2 in it
Having a hell of a time finding parts if the parts store doesn't know what car or year it came out of. Thought the trans was OEM, finding out its not.
Any ideas where I can find the info on this trans?
