Re: 1981 malibu rebuild
if i was going to fix this car all i would have to do is unbolt the motor mounts and pull the engine/trans together, then take the body off the frame.
the firewall on the current car is rotted through in a few spots, this is one.
some of the body mount points on the body are really badly rusted.
this is the driver side corner where the wheel well, quarter panel and trunk floor come together. you can see a rubber body mount puck on the frame, and the body has collapsed in that area where the body mount goes. there is nothing left there. if i was to poke it with a screwdriver there would be a massive hole in this area after i was done.
this is the same spot as above from inside the trunk.
quarter glass window channels
part of the door post is rotted above the vent
its too much work for me, plus just the $$$ i spend on a floor, doors, and quarters I can have another complete car, that is RUST FREE! there is a lot more rust to this car. the rocker panels are rotted inside and out. this car is not worth saving.
I have found another car and i am going to try again, hopefully. If all goes right, I will have a new car in January.
goodbye old friend we had some good times together.
I will update the thread after I get a new car that is in better shape.
