okay, so i think im having either a cooling problem or a thermostat problem in my 83 cutlass w/ a SBC. i was cruising on the highway, and at 1 point the water temp started to slowly rise to about 210+. i had to slow down and move over into the slow lane to let it cool down a bit, which is slowly did back to under 180. i figured since it was slow movement, that the thermostat didnt open up and let water in. also when i push the motor the temp rises pretty high and i slow to let it cool down. now, can i remove the thermostat so this wont happen? are there better or special thermostats out there? i have a pretty much stock fan, should i consider upgrading to an electric fan, or dual electric fans?? ive seen them pretty cheap.
