Weird rattle sound like something stuck in the fan???
Peter
1,175
74
48
MA
Bonegrater said:
Sorry it took a while to reply, the fan has no movement at all. None front to back and none side to side. I noticed it had stopped doing it for the last week or so. Then a friend from work rode with me to lunch, and he weighs around 290-300lbs. After he plopped in my seat I fired the car up and it started up again. After he got out it stopped, any ideas?
could very well be the body bushings compressing from him getting in the car then the fan hitting the shroud
G-Body_Vet
2,937
81
48
Take the bellhousing cover off and see if the noise goes away. I just remembered I had this happen in my Lemans. The cover would slightly contact either the converter or flexplate sometimes while it was running. The odd part is that it didn't do it until it got really cold outside. When the car warmed up it would quit. Worth a try.
It sounded like a card stuck in bike spokes, you'd give it gas and it got loud as hell. Like I said though, after the car got warm it didn't do it anymore. It almost sounded like something was hitting the water pump impeller because it had a metallic sound (metal dust cover).
20,413
I was thinking along the same lines but I'd be checking to see how the frame is...it sounds like a body bushing may have eaten through the frame
G-Body_Vet
2,937
81
48
84hurst said:
The fan shroud is as clean as can be.
This is why I don't think it's the fan contacting anything. The body bushings would have to be really, really bad for that much movement. The only time I had fan to shroud contact was with broken motor mounts on a 400 sbc.
20,413
G-body vet has a good point....84hurst...you need to feed your friend and get him to sit in the car so you can take a good look while the engine is running
Bonegrater
45
Richmond, VA
Thanks for the replies. I am gonna check the bellhousing cover, I looked the frame over and it is like new(southern car) and all of the bushings that I could see or get my hand into were in good shape.
bill
2,332
11
38
southside va/lake gaston
Stamped sheet metal expands and contracts quite a bit in extreme temps. Maybe the torque converter cover has been dented and when its cold out, it bends enough to get hit by the converter. I would also suspect the motor mount(s), especially the drivers side. They may be broken or loose. If your car is a T-Top model, the body can flex much more than a non T-top body would. Just some things to consider :)
