What max size i can fit under rear
Kwik_Cutty88
1,173
662
Coastal North Carolina
On a cutlass? Currently I'm running a 275/60/15 on a 15x7" in the back, which should really be a 15x8". It rubs slighly only when there is a lot of weight in the back, you have to massage the fender lips a bit. That is about as big as I would go without doing a frame notch.
williamattop
455
53
Appleton WI
I ran 235/75/15 for a little while. fit no problem on stock suspension although not a wagon.(pictured).
Im guessing you want to go wider?
Ive also ran 275/60/15 on factory wheels and agree with Kwik Cuttys post about factory width rims.
565bbchevy
9,615
12,683
Michigan
On my Monte a 15" x 8" with 4" of backspace with a 275/60 had no fitment issues at all without a frame notch at that time I was at stock ride height.
Jimmy_D
29
6
235/70 seems fairly close to frame with my rallies
87 GN
232
35
Philly Area
Jimmy_D said:
I was wondering maybe a 245/50ish or a 255/60ish
I run 86/87 regal T-type wheels on my wagon you can get a 255/60/15 in there no issues with plenty of room between the frame. Even a 275/50/15 fits. Your fitment is going to come down to the rim and the back spacing for the rim. With the correct combo you can run a larger then stock tire with no modifications or issues. Its finding the correct rim/backspace or customizing a set to work, for me the T-type wheels work, there cheap, light, and the back spacing is great for my needs.
255/60/15 distance between rear of tire and frame on factory t-type rims
http://s229.photobucket.com/user/turbo2 ... z.jpg.html
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
vwdahn said:
33X21.50-15LT should fit right in there :)
little modification required.
Vic
I wasn't expected to be one-up'd... but, I am glad I was! That thing is awesome.
