1986 regal limited build
Ryebonti123
29
Hi guys new here. I just took out a 307 from my 86 regal and purchased a 383 stroker. 400sbc. Im not sure what headers will fit. Also what motor mounts are needed? Appreciate any help! Ty
6,831
6,741
Is it a 383 or a 400? those are different engines. Standard SBC motor mounts AND frame mounts will fit. idk who sells frame mounts, but motor mounts should be at any parts store.
lilbowtie
3,460
3,965
Canton Mi
I think he means a 383 from a 400, not from a 350 not that it maters they are physically the same.
Is it an AC car
6,831
6,741
How do you get a 383 from a 400? A know you can destroke a 400 to 377.
Ryebonti123
29
Its a 383 from a 400.
lilbowtie
3,460
3,965
Canton Mi
Hooker Comp & Super Comps(Jegs sells there version Comp) - I liked the coated Dyno Max but I don't know if they still make them. Would recommend Shoenfeld (my favorite) but they won't work with AC. I've heard Patriots work well but never used them - maybe someone will pipe up. If you are under 450 Hp 1 5/8 tubes will work. What ever you choose check the application for fitment.
6,831
6,741
How did you get a 383 from a 400? I know a destroked 400 is a 377 with a .030... is it a destroked 400 that's .060 over? That's 382.96 cu. Chevy 400 is 4.125 bore and 3.75 stroke, you destroke it with a 350 crank if I remember right, which makes it 4.125 (stock bore) x 3.48 is a 372. +.060 over is 382.9. Just confused is all.
6,831
6,741
The ONLY other way to make a 383 is a 350 chevy with a 400 crank bored .030 over.
