What year is this and we still waste time with the flawed and failed time and time again 383 strokers?
That settles it then.
Chevy parts grow on trees. Buy new if you can.Im also thinking of buying a complete donor motor. The engine only has a crank pulley and water pump on it. Cheaper to buy a motor or ind. Pieces ?
Yous bought an engine in Milla Place? On 25A?I wish i knew! Im pretty new at this. I bought the motor from a mechanic, brought it back to the machine shop that built it. Elsasser in miller place ny. They told me that it was a 400sbc, 383. Guess i could have mis understood him when he said 400, it also says 383 on the flywheel.
That sounds vaguely familiar from my Riverhead days.Engines by Elsasser Mad Scientist Race Engines.
Mostly roundy round engines
Never used them Never heard good or bad about them.
Ask them what shop balanced the engine.
I am curious if they will tell you the truth
*polyurethane, and never go solid. no reason to unless it's a hardcore racecar. Poly will be fine, local auto parts stores should have them. You will need the frame mounts as well, don't know if they carry them. You will need a poly trans mount too. If you have a mix of rubber and poly you can break stuff. Rubber motor mounts and poly trans mount = broken trans.Okay. What type of motor mounts should i go with? Solid or promethane...
My 86' Regal has a dual pattern 200r4 and changing frame mounts and getting pulleys etc. for the SBC is a relatively easy task, the problem going with an Olds engine is availability, I know around here I never see a good running B.O.P. engine for sale and if you find one they are usually torn apart and people get screwed daily from machine shops if you don't already have a good one you can trust.Question: why not sell the 383 stroker and get an olds 350? It will bolt right in.
