hows your thermostate
jlat
250
61
hello people: Just wondering how many oy youz run a 160 stat with a aluminum rad. I 've been jumping around the try a 180 in my 86T. thanks men
IBBY
Clone TIE Pilot
3,869
2,622
Galaxy far far away
Generally it's best to stay with the stock 195 Tstant, 160 is way too cold.
1KWIKSIX
234
336
Mississauga , Ontario, Canada
IBBY
Changed over from a 160 to 180 T stat since installing aluminum radiator . The 160 didn’t allow warm enough engine operating temperature . If yours is a race car then keep it but for the street definitely go with the 180
bracketchev1221
1,421
1,664
180 is good enough to boil the water out of the oil. 160 is a little cool for me. I ran one in my race car because I didn’t need it getting hot.
Podagrower
17
11
I can tell you that a 160 thermostat with piss poor electric fans that don't come on until 200 will not work.
Ernest
758
1,032
Texas
I still run a copper/brass radiator(3core)... it had a 160F thermostat when i bought the car, engine ran too cold for my liking, so out it went and a 180F thermostat put in its place.
Rt Jam
598
594
Ontario Canada
A thermostat's job is to regulate flow to the radiator. If anytime your temperature is above your thermostat temp. It means your thermostat is WIDE open and is no longer regulating.
9,619
12,709
I have a 180 in my Monte with a 565 Big Block and in my Regal with a 355 SBC and both are running big Griffen radiators with dual Intrepid fans, no cooling issues at all with either car with the 180 thermostat.
