your fav/ best/ craziest gbody shuffle
L05edSS
242
135
ok didn't quite know what category to file under BUT while these shuffles look cute fun & deliberate to the outside eye watching 1 go down, generally the driver has their piss pants on and heard the term recently 'beer pants", regardless you know it when you're in it...
i gotta say the guy just standin there, priceless.
5,759
12,352
I think that video isn’t considered G body shuffle. The ‘shuffle’ is most commonly referring to the side to side tilt that occurs in a GBody when launching hard. My avatar photo shows it well.
Supercharged111
4,995
7,825
Colorado Springs, CO
I've been having these float across my algorithm. Most are crap, cars just not hooking. But a few have had the rear end consistently list off to the left like this one here.
I'm still curious what the real definition is of it. I don't see anything about the car that should make it want to pull one way or the other?
  • Wow
bracketchev1221
1,449
1,714
I think it had to do with the natural tendency of the car to try to lift the passenger side rear tire off the ground and then driving the car right and having to steer it back as it moved around. But that was A and G body cars.
Supercharged111
4,995
7,825
That's any stock axle car though, that's not unique to a particular platform. It's because of the direction the driveshaft spins.
bracketchev1221
1,449
1,714
That’s true but leaf spring cars didn’t suck the passenger tire into the wheelwell like link suspension cars do. Every stock suspension non modified a and g body was hard leaned over with the driver side front wheel in the air
Supercharged111
4,995
7,825
I see. I believe what happens there then is once the rear LCA lifts up past parallel with the ground, the forward thrust keeps pushing it farther up into the wheel well (more so on the right than the left) which exacerbates it. At that point, the right rear wheel is pointed a bit to the left and you've got some rear steer. Now it makes sense. But if that's all there is to it a set of drop brackets should fix a guy right up, no? Or make it less bad.
bracketchev1221
1,449
1,714
Well what happens more than the rear steer is it plants the driver side rear tire hard and lifts the passenger rear tire. So that with a spool drives the car hard right. Then you leave with the front wheels turned left in the air. Then when it lands you drive it around to get it back straight.
Sweet_Johnny
Has A Face For Radio
803
1,501
Wichita, Kansas
bracketchev1221
1,449
1,714
For years, we thought the cars were driving the passenger side tire into the ground with the body roll. But actually it was the opposite.
