So..........Figured it out finally!!!! Changed out gas tank and fuel sender.
Clogged sock.So..........
what exactly was causing your issues? Why did they need changing out? Fuel sender sock filter clogged/dirty?
That'll do it every time.Clogged sock.
Fuel pickup sock if it's not the main bearings no really I didn't seeBoth..... so after ~20min driving will stall then I will leave off for a min or so and will start right back up and drive again for a mile or so. When I get the car finally back home I left it idling for about 10 min and it will stall out.
