Looking to find Claret/Oxblood in an aerosol spray can to shoot my steering column once I pull it and prep it. Found this company not much info on em.
everestautomotivemarket.com
Pretty pricey for a 12oz can. But if it's good quality and close to the color I need, I'll pop on it and the clear.
I have SEM interior paint that is burgandy but it's for plastics and fabric (used it on my RC car replica). So will not use that on the column.
Where else should I look before I start spending money lol. I have no problem spending it, as long as its quality paint and a good color match.
GM Dark Claret 99
Color appeared on 1982 GM models. The 2 oz. size comes with a paint brush built into the cap and is perfect for use on areas smaller than a dime. You can also spray an area of up to about 2 square feet if you reduce 2:1 and have your own equipment. Reduce
