CUTLASS Steering Column Paint?
Honestly don’t recall I wound up doing a bunch of other interior pieces and I think eventually I wound up buying either six or seven cans
Thanks fellas. I start vacation the 24th so gonna get down on this interior then.
Reactions: Ugly1
565bbchevy you think one can will be enough for the steering column or should I grab 2? Also did you top coat yours with a clear?
1 can should be plenty for the column and I used SEM low gloss clear as a top coat for protection.
I have always used SEM color coat but they don't have a burgundy that matched my interior which is why I bought these instead, but it worked out just fine.
Thank you. I grabbed one can and will compare color to the SEM burgandy that I have. I appreciate the response!
on dash and console i use a scrub brush and spray 9 rinse with water after it is good and dry just before i paint i wipe it down with paint thinner then put a tack coat right away ..the paint thinner softens the plastic a little so the paint sticks better
Reactions: RICKDIZZLE
