You're a true artist, D....and my hero.
😊👍 Awesome work.
Simply amazing!
As soon as I saw what you wanted to build I said "OOOH, WOW" and tuned out the rest of the world as I zoned in. I wasn't expecting you to have so much completed either, which was another treat in addition to having a solution for the flimsy, floppy filler panel. Having the right tools and knowing how to use them sure looks rewarding!
Having worked on that part recently, you got my attention. I wondered how the heck you were going to recreate it in metal? You make it look easy, incredible job! 🏆
AMAZING!
This is what I wish I could have done for Jr,'s Monte's plate pocket instead of the extra plastic one which I hope won't decay like his original. Chevy had a steel one for '78 which is nice (one was included with the '79's extra parts) but was done away with & won't interchange with the '79/'80 one.
You're a true artist, D....and my hero.😊👍 Awesome work.
Simply unbeleivable! Amazing craftsmanship!
Wow, That's pretty awesome work Donovan. It look smoother and straighter than the original. What material is the original made out of? Is it that sort of fiberglass type material, or is it urethane? It looks like it’s coming along well. Looking forward to your next update.
Using it as a core it could have the outer edges altered to work with the '79/'80 taillights. Then there's the lower edge that would be the challange due to the way it is for the lower plastic trimthat needs to be glued/siliconed to it. In a way I wished the plastic used would of been more like the stuff used in modern bumper covers & most plastic cladding.It’s unfortunate that they changed some things between years, and that not everything interchanges. Even with a little customizing, is there still no way to make the steel one work? I sometimes forget that the plastic bits really didn’t survive well down there south of the 49th. Perfect example, Buick Regal bumper fillers.
