What did you buy for your Gbody today? (2025)
Got my new door sills today! Talk about motivation to get this interior back in. I am just about done with getting interior pieces engraved. 😎
So much better than my stock ones lol.
I'm really loving em!
It will ultimately be used for them all, but think it is the most beneficial to the Monte
Useless on my trucks, but great for something that's a tighter fit to get underneath. I got one of those a few years ago and I do like it.
I have one, and with the Bauer 2300 psi washer it does work to clean sand and dirt but doesn't quite knock off the heavy stuff.
New springs for the rear coilovers. The ones on the strange coilovers I got from my buddy were 100 lbs springs. Also ordered one of the knobs I broke while installing them.
Ordered a replacement cover for the ripped Corbeau. It ended being way cheaper than having it fixed locally but they said 4-5 month lead time.
Hopefully picking up a sub and box today.
Waiting on a double din bezel. My brother is giving me a pioneer he used to run. Just need to pick it up.
Bought two different styles of front bumper fillers off of eBay. ABS and polyurethane. Both appear to be pretty good but haven’t tried fitting them to the car yet. Each pair was under $40 so pretty hard to go wrong IMO
At $40 each I'd have bought both as well. Which would you guess has a better lifespan? Ya know, based on thickness and resistance to UV/ heat?
Well, I’ve had some bad experiences with ABS parts but there seem to be a lot of them out there that are holding up. The polyurethane are of course slicker/greasier feeling and will require more prep to ensure adhesion. Also seems to be of slightly rougher surface finish.
Both are pretty thick a little thicker than I expected so they should be fine durability wise. I guess time will tell
I still have all 4 of mine but I think I’m gonna have a friend of mine 3D print me a set before something happens to them.
  • Creative
Reactions: Sweet_Johnny
