2003 Astro/Safari, 4.3 AWD Van w/ rear heat. Its been -20c / -4f for a couple days now
Driving home last night ( just a couple kms / miles really ) and I had no heat whatsoever from the vents ( both front and rear ) however Engine temps were fine.
Once home I opened the hood to check. Heater core lines are cold, rad hoses are warm but not hot. I popped the rad cap and it was lukewarm. Overflow bottle and the rad were both full. Tested the antifreeze a couple weeks ago to -40/-45
Went in for supper ( 30 mins ), came out to inspect further. Started the van to run and I had heat. Def head scratcher but OK. Let it run for 20 + mins. Got up to operating temp and the heat worked fine. Rad and hoses still never got "hot " but it was def warmer than before. Obviously the heater core lines were warm too ( front and rear )
So I started and let the van warm up for less than 10 mins this morning and went to work. Engine temp was fine but no heat again
. Got about 2 blocks and temp started rising enough to turn around for home and it was overheating by the time I got it back to the house ( still no heat )
So I parked the van and walked down to the uhaul and grabbed a half-tonne for the day to get me around. Ordered up a new thermostat, and a water pump but still scratching my head.
My thinking is that if the thermostat was faulty ( stuck closed ) then I should have interior heat. If the waterpump was bad it should be making some noise, or leaking from somewhere. But its dry all around from what I can see. Cant really see much flow thru a full rad when its at idle but when you rev the engine it comes out the top of the rad so its producing some flow. If the diverter valve was faulty ( blocks the coolant flow when the ac is on ) it should not cause the van to overheat
Anybody have some other useful suggestions ? Dexcool was all flushed out last summer over the course of a week and switched over to reg green antifreeze. I am leaning towards a weak waterpump or sticky thermostat. The van is 10 years old, 200k kms on the clock and never been opened up. Its been solid since day #1
