11 half inch on monte carlo
it fits
  • narrow frame 4 inchs
    Votes: 0 0.0%
  • fender well shorten 2 half inchs per side
    Votes: 0 0.0%
  • Total voters
antonC4Gbody
15
17
55
arizona
19x10 inch rim and 14 inch rotor
Reactions: Turbolq4
enjoy more pictures after the frame is welded on
How are you keeping the frame sections aligned so all the body mounts stay true? I wanted to do this swap with a GTO/G8 subframe swap...
:popcorn:
:popcorn:
the new frame fit inside the original frame and had brace welded on outside before cutting anything. I have video on youtube under [11 inch tire on narrow frame G body]
Pretty cool, like to see more.
Reactions: Turbo Zach
Reactions: Wraith
Lower or a larger tire? Should handle be pretty good with all that rubber on the ground.
Reactions: Wraith
