Falken ZIEX ZE-502
... my brother put a full set on his last car, a 87 Firebird. The Falkens, are cheap for a reason... they are incredibley soft, and yet offer poor grip. And the soft compound means you'll wear the tread down before you know it.
They are also a tuner brand, so somehow they are skinnier than they spec them for. For example, my brother's 275s are no wider than my BFG 245s.
I would consider looking at Sumitomo, Nitto, or even Kumho, before Falken.
these are also tuner brands, but I've seen nicer tires and better performance from them. They are also wide like their Amercian counterparts like BFG and Goodyear.
you could opt for the Falkens, but you'll need tires pretty soon again. Or you could get tires from say Nitto, and they'll last alot longer. Nitto just came out with a 275/50R17, which a taller and more proportional tire for our cars. A friend of mine just got a set on his 69 Cutlass, which is lowered, and they fit great. I believe they are 245/50R17s infront.
to run a 245, you need a 17x8 wheel
to run a 275, you need a 17x9 or even 17x9.5 wheel
it looks like the 17x9s have alot backspacing... so you will likely need a 1" adaptor.
Or, you could run 245s on 17x8 all the way around.
