1970 Olds Cutlass S Rat Rod Style
I would never put another one of those flexplates in my car regardless of who thinks they are good. I ran a 1000 hp drag car with a transbrake and never broke one like that, especially on a street car with no load on it.
So these arrived, Peyton's covers are super nice but triple the cost. These look really nice along with the welds, I like the short outside edge. The baffles look good and they fit 1.25" grommets. Similar height to stock covers but gain from the shape and no recessed gasket ledge.
Those look really nice, but being nearly stock height will they clear a high lift roller valvetrain with true roller rockers and poly locks?
I bought 3/8” tall aluminum spacers to make sure my chromed ‘74 only covers will clear my Harland Sharp roller rockers.
Reactions: Sweet_Johnny
I had the same question. They've got very affordable valvetrain oilers that would also provide the necessary 3/8" height on a Chevy, but have never looked for some to fit Olds.
74 only? Do you mean the 73 only Oldsmobile script covers? I have painted Oldsmobile script valve covers on the 350 currently. I compared the new covers to the aluminum Edelbrock valve covers without baffles, which are marginally taller to a set of 260 valve covers on my shelf. The new aluminum valve covers are a good 1" taller than stock valve covers, on the edges, even more. They should clear with ease and look good doing it.
74 only? Do you mean the 73 only Oldsmobile script covers? I have painted Oldsmobile script valve covers on the 350 currently. I compared then to the aluminum Edelbrock valve covers without baffles, which are marginally taller to a set of 260 valve covers on my shelf. The new aluminum valve covers are a good 1" taller than stock valve covers, on the edges, even more. They should clear with ease and look good doing it.
Yes, ‘73 only. Fat finger **** up.
Reactions: olds307 and 403
Ok, so I installed the the Transgo 4L80E Transgo HD2 shift kit. The good, it comes with a new seperator plate. You do have to drill two holes, pressure relief and you actually add a spring loaded pressure relief valve and plate to the actual valve body. New bigger boost valves, stiffer springs, not only for the line boost but for the accumulator overall and 1-2 and 2-3. The bad, it could have used a 1-2 accumulator O ring, since it needs removed to change the spring. Mine was stretched, freezing didn't help enough and actually caught and pinched itself. It seems to do the job sealing, still but may pick up a sealing kit. There was a small bit of dirt or clutch material in the pan and the valve body. I used a shop vacuum then carb cleaner and rag to remove the drill shavings and dirt. See if it is any different. Was barely noticeable part throttle and firm at WOT. I set it at the base level, tweaked with accumulator springs, two vs either one large or small for firmer and very firm.
The torque converter bolts went right on the new flexplate and everything is all together. Fluid and will double check the shifter linkage before fire up tomorrow. The cooler lines no longer touch the body, which is good.
So I went to fire up the Olds on Sunday, no go. I did have the battery unhooked for months. No communication from the Terminator X Max with either the handheld or laptop. It showed no firmware file. Talked to Mark and said unhook the battery and try again, I already had. He said look up unbricking the Terminator X Max. I needed to download and unzip then put the Terminator X V2 SD card contents on said SD card. That part is done. It should read it on boot up, is my understanding. I will try it this weekend. If that works, I will also reload my tune and do some flexplate and 4L80E testing on the jack stands.
So no communication, no matter what I tried with the Terminator X Max. So here is my solution.
Honestly I don't feel like spending more money on this EFI. Plus not too thrilled to send anything South. I also found corrosion on the EFI distributor cap and rotor. I have a cheap Amazon manual transmission harness and box for the 4L80E. I just need to see if I can get first on my Fastgate shifter to reach all the gears. The huge spread between park and reverse might make it very difficult. Performer intake is on, new Carter fuel pump is on running fuel lines and I put the distributor to #1 TDC before I pulled it. I want to actually drive my 70 Cutlass this Summer.
