84clonewars said:Are you sure you have the alternator wire charging your system?
kuruption109 said:hey saint im not sure if anyone else has told u this but man i look forward to opening up ur thread becuase i kno everytime i see an update its sweeeet and man u have came a long way from not knowing anything bout these cars to basically building 2 clean *ss gbodies keep up the hard work bro..
procircuit said:Just read your whole thread... lookin damn good!
keep it up !! :!:
L.A.X-RATED said:homie,homie,homie!!!! you dont need to BUY anymore metal!!!??? do like i told you just reuse the piece you cut out,flip it around and it will lay in the cut out section PERFECT(MAY NEED SLIGHT TRIMMING/persuassion from a bfh)then get you a good stick welder(220 amp preferably,wire feed will work,but more time consuming))and have at it,if your bro -in-law is a welder,or even the muffler shop can do this,its CAKE dont let them work you.id give them the MOST 50.00 to do this.after you get it done buy you a pint of por-15 rust prevenative paint(30.00)and give it(crossmember)a good bath in it and let cure for a day or 2 and follow up with a top-coat of choice(rustoleum,krylon,etc)
