Here’s a few pics of the t56
I ended up cutting more than I needed to to get the transmission in. I had read lots of threads about putting a t56 into a gbody and some have said nothing more is required than a hole for the shifter(that was said about a regular T56 not a t56magnum) . Heard from other people you have to cut a huge hole. I went in only wanting to cut out as much as I needed, but when I was fighting the motor mounts the first time setting the motor and trans in I kept wanting to jack the trans up to see if that would help and cut more than I needed. Honestly after getting new motor mounts and bolting the drivetrain in, I feel just a hole for the shifter will suffice for aT56 Magnum in the Gbody tunnel. It’s pretty tight though.
I’m gonna cut a little more so the trans has more room and build a proper patch here soon. Pretty much all the pictures I have of the trans right now. I’m hoping to go down this weekend and maybe put the drivetrain back in to take some more photos of that trans in there for those of y’all that were asking and work on the patch.
