1980 cutlass/chevy 350
My SBC has the truck mounts on it, straight from the truck into my car. The only difference there is the height of the mount, which will compromise your hood clearence. Also, if you swapped transmissions, make sure that you have the correct crossmember.
cuttyred said:
the trasmission and everything is together the mounts to the motor may be truck mounts or is there a different
looks up the part numbers. if they match they are the same, but since they do not fit I am guessing they are not.
Truck mounts will cause your fan to hit the top of the fan shroud...
I ran a 15" flex fan and it fit just fine with the factory fan shroud
well today I call napa and they said they have a universal mount kit and it should work so I will let y'all know if that work
well guy I finally got the motor in I had to spend 126 dollars for some moroso mounts to the frame and motor now the drive shaft is to long and the crossmember doesnt fit so now what
I know hot rod is not cheap
Hmmm.... driveshaft is too long and crossmember doesn't fit. Did you change trans, too? Like go from a th350 to a th400?
