1980 Malibu turn signal lever
malibu man
7
I picked up a tilt colum for my car,but it doesn't have the turn signal lever. I thought it would just unscrew form the old one(this is a 1980 model,so it only works the turn signal/high beams),but this is not the case!
Anybody know how to remove the arm?
I have the old colum apart,but still cant figure how to get it out!!
-83MONTESS-
4,570
967
Bellevue, Ohio
Its been awhile since I messed with mine but I think you just push in, turn it counter clock wise and pull outward. It was a b*tch coming out for me the first couple times.
Ribbedroof
4,914
7,035
Wellston, OK
It should have a screw into the turn signal switch holding it. As I recall, the push/turn levers were begun when the wiper switch moved to the column. The older ones are like the old style columns, but with a metal lever added under the screw to run the dimmer switch
Bowiemontecarlo86
693
16
Tampa fl.
I thought the lever you just grab and pull out? That's the way it is on my 86 Monte . Maybe its totally deferent from 1980.
Ribbedroof
4,914
7,035
Wellston, OK
Like I said right above :roll: , that's true for those with wiper switch on the column...which began around 1982
80ELCAMINOFLAKE
2,685
14
38
California So Cal
That it correct the turn signal is connected with the screw...the turn/wipers came push and turn, and the tilt can be unscrewed
