1980 Pontiac LeMans Station Wagon - G-T-faux (stuck with it, and can't shake it... like a bad case of herpes)
81cutlass
4,650
13,575
Western MN
SR-SB-PA is probably the best class. SME is a 10.0-10.5 class now so you won't get into the bracket. Almost makes more sense to run SR-SB-PA anyways so you get more runs in.
If you didnt see in my thread, the cheapo receiver hitch frame you can probably but at princess auto or whatever canadian version it is works good. Generic trailer lights literally bolt on (holes are already there)
For cruise I would put in a 83+ column with the newer switch that hooks right up to the GM module. Just splice wires. Keep in mind the GM cruise looks for resistance at the taillights, I had issue on mine and had to add resistors for it to see the tailight circuit was there and would shut off when you hit the brakes.
Dragweek should be fun!
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
So - I got some unfortunate from my brother yesterday: he's backing out of doing Drag Week with me next year. This throws a real wrench in my plans, not only because we don't get to do another road trip together, but also he is about the only person I trust to wrench with me. Natasha is still encouraging me to plan to go - I am not so sure I want to put the effort in... Maybe I just need to focus on getting the MCSS off the ground (figuratively and literally)?
motorheadmike
8,976
27,522
My garage monkey with the latest airflow booster. Now I just have to find a filter to fit it... or not.
motorheadmike
8,976
27,522
Pssh! Pssh!
Pardon the contrast... it is bright in there. Leaks checked for and ready to rock.
motorheadmike
8,976
27,522
motorheadmike
8,976
27,522
I totally forgot to mention it is set up with a #52 nitrous jet and a #25 fuel jet. This is smallest I could jet the fuel side down on 58psi fuel pressure with the assortment I have. But, I can go really big - LOL
Depending who you ask or the calculator you use this is a 100-125hp shot.
