1980 Pontiac LeMans Station Wagon - G-T-faux (stuck with it, and can't shake it... like a bad case of herpes)
motorheadmike
8,976
27,522
Saskatchewan, Truckistan
what did you install to limit the steering?
Welded on some 3/8" rod to the bracket that connects to the LCA and bumps into the spindle at full lock.
motorheadmike
8,976
27,522
I did the same thing but with a bolt and two nuts. I have that patented so you owe me some $$$$$.....:p
I don't want to hear about your little nuts and bolt. :D
Clutch
5,189
10,913
Brick NJ
Sorry Mike I know nothing of what you speak that's why I have so many carberetors lol
motorheadmike
8,976
27,522
Is there a way to log the output on the MAF?
Yes, and I do. Frequency (Hz), g/cyl, g/sec, calculated dynamic air, etc.
That is why I was saying something is wonky - because comparing datalogs a month apart showed an obvious change in Mass Air Flow.
motorheadmike
8,976
27,522
Mike, my buddy with the ZR1 has recently switched to speed density for similar problems. It had a light throttle buck that no one could tune out with it being MAF.
The car runs as well as it ever has even with this issue. It just goes lean. I actually converted it to a MAF/SD OS to improve the driveability last year. I will try setting it back to SD-only to see if it improves any.
Oh, and the cold front we just had move - well it had no effect on the situation.
